Export alpha Channel Small size/dimension file After effects Cs5
I am trying to render a 10 seconds video with the alpha channel with AE CS5. I used first Animation codec and then png with rgb+alpha, but the size of my file is always of 400 Mb. I need to reduce the size but not the quality because I need to import this video into an application.Can you suggest me anything?
Thanks a lot! 🙂
