Activity › Forums › Avid Media Composer › Export all files for a given project as a backup?
Posted by Dragos on March 1, 2012 at 3:09 pmIs there a way to export all of the given files for a project onto a separate harddrive? I’m new to Avid (FCP user) and I wanted to see if there was any command that would consolidate all files and all bins for easy backup once a project has been completed.
This would be similar to what you can do in Apple’s Motion application. I was hoping there was something similar in AVID.
Ronn Kilby replied 14 years, 6 months ago 4 Members · 13 Replies -
Michael Hancock
March 1, 2012 at 3:19 pmhttps://automaticduck.com/products/mc/
Download mediacopy from the link above. It’s free now and will do what you want. Every Avid editor should have it in their toolbox.
Michael Hancock
Editor -
Shane Ross
March 1, 2012 at 6:42 pmWell, that copies the media used in the SEQUENCE…via an AAF or XML.
“Media Copy is a helpful application that reads an Avid AAF or OMF 2.0 file or a Final Cut Pro 7 XML file, figures out which media files are used by that sequence then copies the media to a location you specify. This can be quite handy when your media files are strewn across your system, or you just don’t know which media files are represented in your edited sequence.”
You can do this just by Consolidating your sequence, with handles…or without if you want the full clips. Don’t need the Duck for this.
If you want all of the media in the entire project, then you need to consolidate the footage. Either bin by bin, or make a single bin with copies of all the clips, and consolidate that. Then relink to the footage on the new drive.
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Michael Hancock
March 1, 2012 at 6:46 pmKeep reading the next paragraph Shane. Mediacopy 3 also reads bin and prject files for archiving. It does exactly what the OP wants.
Michael Hancock
Editor -
Shane Ross
March 1, 2012 at 6:50 pmGod…now I feel STUPID! Why did I not read that far? I read what I knew was true…and stopped.
Sorry…*headdesk* moment…
Shane
Little Frog Post
Michael Hancock
March 2, 2012 at 1:58 amLol! It happens. I was using MDV and had used MediaMover before that, then MediaCopy v3 came out and it did everything I needed and more. Now that it’s free it’s even better!
Michael Hancock
Editor -
Ronn Kilby
March 5, 2012 at 6:43 pmMichael – once one has archived a project using mediacopy, how does one get it back? I did a test, copying all bins etc to a portable drive, copied the avid project file to another system, then opened the project on that system. Tried to relink the files and sequences to the portable drive, no go.
Michael Hancock
March 5, 2012 at 7:08 pmThe Avid media has to be in the right folder structure at the root of your drive. It goes like this:
DRIVE\Avid MediaFiles\MXF\1\Media – where 1 is any numbered folder (could be 1, 2, 53, 75, etc), and the Avid media goes in it.
Once you have these folders set up and the media in the numbered folder, start Avid and it will scan the drive and reindex the databases. Now when you open your project it should automatically relink. Chances are your media isn’t in the right place so Avid simply doesn’t see it.
Let me know if this works.
Michael Hancock
Editor -
Ronn Kilby
March 5, 2012 at 7:15 pmThanks Michael – that was it exactly – my AvidMedia folder was within an archive folder on the backup drive. Moved it to the root and works like a charm. Big duh moment.
Michael Hancock
March 5, 2012 at 7:25 pmAre you on a PC? If you are, you can used the subst command to make the OS think folders are drives – it’s awesome for bringing an archived project back to life for a minor change. Saves you from having to move the footage from its archived folder and moving it back.
Let me know if you’re on a PC and I’ll find an earlier post about using the subst command.
Michael Hancock
Editor
