Activity › Forums › Adobe After Effects › Export AECS5 Project Layers as Files
Posted by David Schlosser on February 3, 2011 at 4:48 pmIs there a way to batch export every layer of a project – so that each layer becomes a file with an Alpha Channel?
Any help would be appreciated.
-David Schlosser
da***@***************ty.comTodd Kopriva replied 15 years, 3 months ago 4 Members · 6 Replies -
Walter Soyka
February 3, 2011 at 5:18 pmIn After Effects, you could use Composition > Save Frame As > Photoshop Layers…. Next, in Photoshop, open the file and use File > Scripts > Export Layers to Files…
Perhaps there is a script that would let you do it directly from AE, though I don’t know of one offhand.
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
David Schlosser
February 3, 2011 at 5:27 pmThank you so much for responding – I may have found what I’m looking for:
https://www.redefinery.com/ae/view.php?item=rd_RenderLayers
I am about to test it now.
Ideally it will result in an individual .mov file for each layer (w/alphas)
-D
Walter Soyka
February 3, 2011 at 5:44 pmThat looks like a really useful script!
The only thing I’d caution you to keep in mind is that transfer modes can’t carry over into your single-layer renders. If you need to reconstruct the project, you’ll have to manually reset the transfer modes.
When I split projects out like this, if I have used any mode other than Normal, I add it to the end of the layer name / file name (for example, “Way Overused Lens Flare – Screen”) so it’s clear how to reconstruct it.
Walter Soyka
Michael Szalapski
February 3, 2011 at 7:41 pm[Walter Soyka]“Way Overused Lens Flare – Screen”
*snicker*
– The Great Szalam
(The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
Todd Kopriva
February 3, 2011 at 9:40 pmJust curious:
Did you find that script by asking on Twitter?
Technical Support for professional video software
After Effects Help & Support
Premiere Pro Help & Support
