Activity Forums Creative Community Conversations Export actual .MXF file?
  • Export actual .MXF file?
    Posted by Nathan Adam on October 26, 2012 at 1:07 pm
    Hey all, edited the last 2 seasons of a show in FC7, and was always able to export a .MXF (Not .mov) file to deliver to the network with their specs (XDCam HD 422, 50Mbps, 60i)…
    I can export with all of those same internal specs from FCX, but it’s a Quicktime .Mov and they’re complaining about having to transcode.
    I believe it was a plugin I had to install in FC7 to enable exporting .MXF file, but googling “how to Export .MXF from Final Cut” brings up pages of “how to IMPORT .mxf” instead.
    I can’t be the only person encountering this problem. Advice?
    Alban Egger replied 13 years, 11 months ago 3 Members · 2 Replies
  • James Cude
    October 26, 2012 at 3:45 pm
    In order to export to MXF in X, you need the Hamburg Media Pro plugin, the Calibrated is for import.
  • Alban Egger
    October 26, 2012 at 7:28 pm
    I am currently testing the plugin and let you know. We also need xdcam422HD with 8 audiotracks as MXF
