Activity › Forums › Apple Final Cut Pro Legacy › export a single frame to tiff of png
  • export a single frame to tiff of png
    Posted by Jeffrey Levenstone on November 4, 2005 at 11:37 am
    Is there someway to export a single frame from finalcut pro. In combustion for instance in the file menu there is the option save image. It then deinterlaces the image and saves it to the format of choice. Is this possible in finalcut pro.
    Jeffrey Levenstone replied 20 years, 11 months ago 3 Members · 3 Replies
  • Rozenberg
    November 4, 2005 at 12:13 pm
    Go to file – export – as quicktime (or something like that) in the pull down menu you can choose what kind of export you want to do and a still is one of the options. You can even specify what kind of codec you want to use.
    _______________________________
  • Thaxter Clavemarlton
    November 4, 2005 at 12:17 pm
    To be more specific-
    Step 1: File> Export> Using QuickTime Conversion… “Save” window appears
    Step 2: Format> Still Image
    Step 3: Options… > Format: (choose PNG, PICT or Photoshop) > OK
    Step 4: Name your image, Set location (disk, folder, desktop) for your new still. > Save
  • Jeffrey Levenstone
    November 4, 2005 at 12:26 pm
    Hey Rozenberg and Thax,
    Thanks guys for your quick response. You just helped me out of a lot of working around.
    Jeffrey Levenstone
