Activity Forums Apple Final Cut Pro Legacy Export a portion of timeline to livetype??????
  • Export a portion of timeline to livetype??????
    Posted by Ed Stevens on July 29, 2005 at 8:45 pm
    My SYSTEM
    MAC dual G5 2.5 gig. 4.5 gb RAM. OS 10.3.8
    Blackmagic Decklink Extreme card v4.8b
    FCP 4.5 production Suite
    500GB G-Raid Firewire800
    Decks = Beta-SP, DVCpro, DigiBeta.
    Audio Mix = Mackie 1604 VLZpro
    I have tried everything. First I do not know how to make a
    quicktime file from a portion of the timeline. When I export to Quick time moive and try to open it in Livetype, I see it.
    When I try to Place video background movie I see only a black background. What am I doing wrong????
    Please help.
    ED
    Robert Garry replied 21 years, 1 month ago 2 Members · 1 Reply
  • Robert Garry
    July 29, 2005 at 9:52 pm
    There should be a function to export to LiveType. File>Export>Export to LiveType. If you have and In and an Out set in your sequence it should export only the section you have inside these points.
    As far as the black movie goes….have you toggled off the visibility on the left side of the track that contains your movie? Perhaps your movie was exproted incorrectly and you output only black? The only other thing I can think of is that you have some kind of element on a text layer above the movie in LiveType that is obscuring your view of the movie.
    if you can’t get the portion of the movie you want into Livetype try creating a new sequence and deleting everything EXCEPT what you want to send to Livetype. Then export that entire sequence to LT, when you are done creating in LT bring the LT file back into your original cut and everything should be groovy.
    Good Luck
