Activity Forums Adobe Premiere Pro Export 60 fps clip at 24 fps
  • Export 60 fps clip at 24 fps
    Posted by Alberto Bedin on December 20, 2014 at 5:49 pm
    I recorded 50 clips at 60 fps.
    I created a new sequence at 24 fps.
    – Some clips were conformed to 24 fps and placed on the sequence in order to slow them down.
    – Other clips were time remapped.
    – Remaining clips were placed in the timeline at normale speed (60fps).
    My question is: when I export the sequence at 24 fps, what happens to 60fps clips? Premiere remove some frames? How? Or does it blend them?
    Since I record clips at 60fps with 1/120 of shutter speed, will I get choppy movements?
    Ivan Myles replied 11 years, 8 months ago 2 Members · 2 Replies
  • Ivan Myles
    January 4, 2015 at 3:07 pm
    If you do not select frame blending Premiere Pro will only use two out of every five frames and drop the other three. A series of frames like ABCDEFGHIJKLMNO at 60fps might appear as ACFHKM at 24fps (or possibly ADFIKN or BDGILN).
  • Alberto Bedin
    January 21, 2015 at 9:51 pm
    Thank you, clear answer.
    Is this “sub sampling” usually noticeable?
