  • Posted by Popnerd2002 on January 24, 2007 at 12:49 pm
    I have 17 gig of dv footage which is about 3 hours of footage, i’m making a dvd but am having problems exporting the footage and keeping it to a decent standard as well as making the file size much smaller. I dont mind putting the footage on two dvd’s as long as I can keep the picture quality up. Can anyone tell me the best compression settings to use?
    Please.
    Thanyou
    Mike Velte replied 19 years, 7 months ago 5 Members · 9 Replies
  • 9 Replies
  • Mike Velte
    January 24, 2007 at 1:04 pm
    Video compression is about compromise. You can have high quality OR small files…not both.
    The best quality setting (using premiere) would be 7.8 mbps (video) , but that would require 3 discs and take your total bitrate to 9 mbps which is higher than most folks would take duplicated discs.
    Using Encore or Premiere Elements with Dolby audio could take your video bitrate up to 6 mbps which is 1.2 mbps higher than Premiere for 2 discs.
    https://www.video2stream.com
  • Harm Millaard
    January 24, 2007 at 2:07 pm
    17 GB of MS-DV AVI type2 footage is around 80 minutes, not 3 hours. What codec is used if it is 3 hours?
    If you have Encore, export to movie, import the movie into Encore and have Encore do the transcoding. Otherwise use a bitrate calculator to find optimal settings for the transcoding to MPEG2-DVD.
  • Aanarav Sareen
    January 25, 2007 at 2:24 am
    [popnerd2002] “I have 17 gig of dv footage which is about 3 hours of footage”
    Are you sure it’s DV footage? What codec?
    Aanarav Sareen
    premiere@asvideoproductions.com
    https://www.asvideoproductions.com/techtalk
  • Popnerd2002
    January 25, 2007 at 10:58 am
    yeah sorry made a mistake it comes to about 38 gb of dv which is about 3 hours
  • Harm Millaard
    January 25, 2007 at 11:13 am
    For 3 hours I would either use two DVD’s or use DL. Still the easiest way is have Encore do the transcoding. You also have AC3 sound, so it will leave more space for the video, improving the quality.
  • Hector Melendez
    January 25, 2007 at 3:40 pm
    Within PPro divide your timeline footage in 2 sequences as you want best for continuity.
    Export “movie” to be burned at Encore creating a folder as “part 1” for the first sequence. Depending on your system this will take 45 yo 50 min.
    Do the same for sequence 2.
    Import this into Encore, make your menu and burn it. Left Encore do the best settings in automatic.
  • Popnerd2002
    January 26, 2007 at 12:04 am
    What shud i export it as? DV?
  • Popnerd2002
    January 26, 2007 at 12:19 pm
    What would be the best video format to export the footage out of premiere as? would microsoft avi? but wouldn’t the file sizes be huge still?
  • Mike Velte
    January 27, 2007 at 7:57 pm
    [popnerd2002] “What shud i export it as? DV?”
    The purpose of the export would dictate the export settings. For local playback Windows Media Video 9 would give one of the best quality/size ratio at 2 mbps same size as original, but deinterlace in the encoder.
