Activity Forums Adobe After Effects Export 16bit Sequence From AME
  • Export 16bit Sequence From AME
    Posted by Tav Flett on November 7, 2014 at 2:22 pm
    Hi there,
    I was wondering if it is possible to output a 16bit TIFF sequence from adobe media encoder?
    I am currently working on a 16bit AE project and have tried sending my final output composition to the AME however it only seems to render at 8 bit.
    I have checked the render at maximum bit depth option and maximum quality however it still only renders 8 bit and cant find any other bit depth options.
    Any ideas?
    Cheers,
    Tav
    Tim Kurkoski replied 11 years, 9 months ago 3 Members · 2 Replies
  • Brian Charles
    November 7, 2014 at 6:31 pm
    @ Dave. I’ve nosed around in AME and cannot locate an option for 16bit TIFF sequences. Where do you find it?
  • Tim Kurkoski
    November 10, 2014 at 8:11 pm
    Adobe Media Encoder doesn’t have larger than 8bpc for the still image formats.
    I recommend you use the Render Queue in After Effects for still image sequence exports of After Effects comps, for this and other reasons (alpha channel support, output file naming templates).
