Activity › Forums › VEGAS Pro › Exponential Rate of Change
  • Exponential Rate of Change
    Posted by Daniel Hughes on April 25, 2011 at 1:54 pm
    Hi folks.
    So Vegas allows us to vary the rate of events by a maximum of 4x and a minimum 0.25x.
    Pretend these are diagrams of sine waves… apologies for their abysmal quality!
    I have this source audio wave:
    So I can do this, 4x faster:
    Or this, 4x slower:
    But can I do this?
    I’m looking to achieve an exponential rate increase or decrease, hoping there is some sort of way to do this in Vegas!
    Thanks 🙂
    Daniel Hughes
    Amateur Writer, Director,
    Director of Photography
    United Kingdom
    Daniel Hughes replied 15 years, 5 months ago 3 Members · 5 Replies
  • Jeremy Rasnic
    April 25, 2011 at 2:12 pm
    Try this: Right click the video file, choose Insert/Remove Envelope. Apply the velocity envelope to the video event. Double click the line that appears to add a node to it. Double click again further down the line and place nodes wherever you want them. Click and drag a node to ramp up or down the speed of the video.
    Since I am not in front of my editing system right now, I cannot test to ensure that this will affect the audio, but I think it does.
    If you do not have a video event attached to the audio, drag a video file to the timeline and ctrl select both the video and audio and then press G on your keyboard to group them.
    Let us know if this worked for you.
    j razz
    https://www.jrazzcreations.com
  • Daniel Hughes
    April 25, 2011 at 3:07 pm
    Ah that’s really cool! Unfortunately it didn’t affect the audio though :(! But I think that will come in useful for something I wanted to do with a video event!
    However, I did just remember a small Acoustica program I had about 4 years ago that allowed to change the velocity of audio… thanks for that Inception!
    Thanks a lot for that anyway! I’ll post here if I manage to do that to the audio in this little software encase anyone else needs to know.
    Daniel Hughes
    United Kingdom
  • Daniel Hughes
    April 25, 2011 at 3:32 pm
    Yeah, anyone looking to do this with audio, download Acoustica MP3 Audio Mixer. It’s shockingly simple software, but it will do this for you if you set the envelope to ‘rate’ 🙂
    Daniel Hughes
    United Kingdom
  • Omer Aydin
    April 26, 2011 at 7:24 am
    You can do it by hand in realtime without using any 3rd party software.
    Here is how;
    Open a new project and load the audio as Track 1
    Add a new audio track and set it to Record mode.
    Add Pitch Shift Fx to track 1.
    Start Recording(*)
    Since Pitch Shift has no automation control, adjust the pitch by hand in realtime while recording…
    Set Track 2 to solo and render it as WAV to use in your project.
    Hope it helps.
    *(Your audio mixer must be set to record what it playbacks.)
  • Daniel Hughes
    April 26, 2011 at 3:54 pm
    Ah yes of course!
    Daniel Hughes
    United Kingdom
