Activity Forums Boris FX expolring BCC Extruded Text
  • expolring BCC Extruded Text
    Posted by Avi Lev on January 17, 2011 at 7:20 pm
    I’m trying to use BCC Extruded Text in the Boris FX but I don’t understand all of the terminology, like in this message:
    “Unable to locate the following file:
    Static Style Text
    Please consult the help docs for guidance on replacing the missing file.
    (or simply choose an alternate map.)”
    What is “Static Style Text” and “alternate map”?
    I’m working on the Avid Composer but have problem to locate the Boris FX Help
    Douglas R bruce replied 15 years, 8 months ago 4 Members · 4 Replies
  • Boris Yamnitsky
    January 18, 2011 at 11:05 am
    Sorry for confusing terms, I agree they should be corrected. I believe in this case the filter is missing the original EPS file that was used when it was initially created. Simply choose this EPS file again via file button (I do not have Avid in front of me at the moment so my terms are loose too). The help pdf should be available via help button. It is possible though that they have been moved from the default location in which case help files will not appear. See if you can find them on your hard drive.
    Boris Yamnitsky
    BorisFX
  • Douglas R bruce
    January 20, 2011 at 12:28 am
    Avi,
    I am in the process of making a series of video tutorials about using the BCC 3D Object filters in Media Composer, mainly on the 3D extruded text filter.
    Send me a PM from the Avid Forums, or email me direct and I will inform you about them.
    Regards,
    Douglas
    PS. On the Avid Forums I am “Drbgaijin”
    Douglas
    (Kumamoto, Japan)
  • Peter Mcauley
    January 20, 2011 at 3:54 pm
    Hi Douglas,
    Should you require any assistance in understand the nomenclature that we used to describe the parameters in the 3D Objects filters please don’t hesitate to contact me. Also, if you need any help in understanding how to use any of the filters within any host, again, please feel free to get in touch with me. You can reach me at peterm@borisfx.com.
    Cheers,
    Peter.
  • Douglas R bruce
    January 23, 2011 at 4:42 am
    Peter,
    I am sorry I have taken such a long time to reply.
    I have just sent you an email with some more information.
    Thank you very much for your offer of assistance.
    Regards
    Douglas
    Douglas
    (Kumamoto, Japan)
