Activity › Forums › Maxon Cinema 4D › ExplosionFX on large objects
  • ExplosionFX on large objects
    Posted by Keiran O’brien on January 26, 2006 at 5:05 pm
    I wish to use Explosion FX on a fairly heavy poly object, but settings that work as you expect them to on a small object, do not appear to work on a large one. Is there some special considerations that need to be borne in mind when using this effect?
    Brian Jones replied 20 years, 8 months ago 2 Members · 1 Reply
  • Brian Jones
    January 26, 2006 at 11:29 pm
    Is your Cluster Type automatic? If so, perhaps if you set the Min Polys and Max Polys upward to reflect the greater number of polys…
