Activity Forums Boris FX Particle Illusion Explosion to follow a path
  • Explosion to follow a path
    Posted by Douglas R bruce on February 25, 2008 at 12:05 am
    I am almost finished with adding explosions to a model of a volcano.
    On static shots I have no problems.
    However when the explosions are added to a moving shot of the crater and I want the explosion to move with the craters motion I am meeting problems.
    If I only move the emitter along the track – the particles don’t follow…
    I guess I need to somehow get everything to move together.
    If anyone understands what I mean…… can you give me some advice or even point me to a tutorial which explains the technique.
    I am sure it is quite a simple task and probably has been covered before….. but I couldn’t find the answer by searching the forum.
    Regards,
    Douglas
    Douglas
    (Kumamoto, Japan)
    Douglas R bruce replied 18 years, 6 months ago 2 Members · 5 Replies
  • Douglas R bruce
    February 25, 2008 at 3:00 am
    Replying to myself!
    After studying Elvis Deane’s Guide to ParticuleIllusion 3 – Offset chapter. I got things figured out.
    But now I found a new problem?
    Making the offsets for the different explosions I had to use Layers (4 in all).
    When rendering the final sequence I only get Layer 0 visible in the rendered avi.
    What is the next basic thing I am missing? How do you get all layers to render together?
    Sorry for such basic and simple questions.
    Regards,
    Douglas
    Douglas
    (Kumamoto, Japan)
  • Douglas R bruce
    February 25, 2008 at 5:53 am
    Yet again I seem to be answering my own question…..
    Am I correct in assuming I must have the top layer active when I save the project?
    It looks like I had layer 0 active….and got only layer 0 when I renedered……. but if I have layer 4 active and on top … then all layers from 4 down are present when rendering.
    Regards,
    Douglas
    Douglas
    (Kumamoto, Japan)
  • Alan Lorence
    February 25, 2008 at 1:48 pm
    Are you just using different layers of emitters? Then it shouldn’t matter which is active when saved — they all should show on the stage and when rendered.
    It could be a bug — what version are you using?
    Can you describe the project in more detail? Can you get the problem to happen with a simpler project (2 layers)?
    Alan.
    http://www.wondertouch.com
  • Douglas R bruce
    February 26, 2008 at 6:07 am
    Thanks for the reply,
    I have version 3.0.3 18Dec 2007 installed.
    I will not have time until tomorrow to do some more tests.
    What details would you like about the project?
    I will make a few screen shots too.
    Regards,
    Douglas
    Douglas
    (Kumamoto, Japan)
  • Douglas R bruce
    March 1, 2008 at 4:18 am
    Alan,
    I was unable to reproduce the problem!
    Hopefully it was just the result of a tired computer….. or, more likely, a tired computer operator.
    If it resurfaces I will try and document the steps more precisely.
    Regards,
    Douglas
    Douglas
    (Kumamoto, Japan)
