Activity Forums Adobe After Effects Explosion timing
  • Explosion timing
    Posted by Jerry Smith on July 12, 2016 at 1:56 pm
    If you have a little explosion (at 25 fps), how many frames would you use to ramp up to the max? I’m thinking the answer has to be 0,1 or 2.
    Same question with a gun.
    Same question with a camera flash.
    Same question with metal on metal, say a spark of a train wheel on a track.
    Michael Szalapski replied 10 years, 1 month ago 2 Members · 1 Reply
  • Michael Szalapski
    July 12, 2016 at 2:24 pm
    Use whatever looks best to you. Sometimes we must make artistic choices that aren’t realistic.
    An explosion will vary a lot depending on the kind of explosion.
    A gun will often flash faster than a frame. Unless you’re firing something like a minigun that fires many bullets every second, often a regular gun can be fired a few times without a video camera even picking up the muzzle flash. And, when it is captured, the flash will only be there for one frame.
    A camera flash will be there for one frame only.
    A spark an be on screen for a few frames as it streaks across.
    – The Great Szalam
    (The \’Great\’ stands for \’Not So Great, in fact, Extremely Humble\’)
