Activity Forums Adobe After Effects Explosion in very shocking footage
  • Explosion in very shocking footage
    Posted by Aernout Ottens on February 29, 2008 at 6:52 am
    Hello guys,
    I’m working on a project for school right now, and I’m making a short action movie. Of course there are some explosions in them, but now I’ve got a problem. I’ve got some very shocking footage and I need to place and explosion in it. I’ve already tried using motion tracking in After Effects, but that doesn’t work. Any Id’s?
    Greetings
    Aernout Ottens
    Aernout Ottens replied 18 years, 6 months ago 2 Members · 4 Replies
  • Matthew Mccarter (macattack)
    February 29, 2008 at 2:32 pm
    Did you try applying the tracking data to a null? If you do that, then you can parent your explosion layer to the null, and it will follow the motion of the camera.
  • Aernout Ottens
    February 29, 2008 at 4:49 pm
    Well, I sure would try it, but the motion is so fast that is isn’t able to track any points at the time of the explosion.
    February 29, 2008 at 5:18 pm
    Oh my apologies. When I read that you tried motion tracking, I assumed you tracked and applied the points to the footage layer itself.
    I believe Andrew Kramer is coming out with a new tutorial soon regarding this matter. Until then, I know he mentions a couple of things in his blog on videocopilot.net to try under his stabilizing footage entry.
    I know you aren’t going to be stabilizing the footage, but you might be able to reverse motion track it. If you can stabilize it, then he has a technique in his Demon Face Warp tutorial that you can refer to.
  • Aernout Ottens
    February 29, 2008 at 5:55 pm
    Thank you very much, I’ve solved the problem right now. I found 1 point with a bit higher contrast in the video. So i was being able to track the motion by hand as well (because of motion blur). The results will be posted on youtube if you are being interested, search for ahottens.
    Thanks for your help
