Activity › Forums › Maxon Cinema 4D › Explosion FX Triangulation Issue
  • Jim Scott
    March 16, 2019 at 8:58 pm
    The Explosion FX doesn’t change the mesh but only works with the mesh that it is given. With the Explosion FX disabled (or before applying it) select Display > Gourad Shading (Lines), or keyboard shortcut N > B, to see the mesh. You will then see that the figure’s mesh is made up of the same triangles that are used by the Explosion FX.
  • Filip Stillerska
    March 16, 2019 at 9:41 pm
    Thank you, Jim! Very good and clear explanation with screenshots.
    However, is there any way to avoid this triangulation thing from happening so visibly? I understand that the Explosion FX needs to break the mesh into triangles, but the Explosion FX is kind of useless if the mesh becomes so visibly “distorted”, unless you’re creating an explosion that is so fast that the audience won’t be able to see this triangulation process. I want to use the Explosion FX to create a “slow” explosion, to simulate something that looks like a disintegration effect. I guess that won’t work, apparently…
  • Jim Scott
    March 16, 2019 at 10:06 pm
    Hi Filip,
    The Explosion FX is not breaking the mesh into triangles — the mesh of the figure is already triangles. Explosion FX simply explodes them apart. Try the Explosion object with the speed set to zero, and animate the strength from 0 to 100%, and see if that’s what your after.
  • Jim Scott
    March 16, 2019 at 11:57 pm
    To minimize the look of triangles flying apart subdivide the mesh a few times — Mesh > Commands > Subdivide (or U > S). In my example below I subdivided twice and applied the Explosion object with a speed of 10 and animated the Strength from 0 to 100% over two seconds.
    13210_explosion.mov.zip
  • Steve Bentley
    March 17, 2019 at 2:47 am
    Perhaps what you are seeing is the mesh once its separated. With the triangles together the phong shading creates a smooth transition between polys (that are less than a set angle of difference). As soon as you separate the polys the phong tag is rendered pointless and you see each triangle as a flat surface and any reflections are severely harsh.
  • Filip Stillerska
    March 17, 2019 at 8:39 pm
    Unfortunately I don’t have the Explosion object or the option to subdivide; I’m using Cinema 4D Lite.
    However, I found a workaround: first I rendered the scene with the Explosion FX, and then I rendered the scene again with the Explosion FX disabled. Then I comped these together in AE. Not the ideal workflow – but once again I’m limited by C4D Lite. The end result is exactly what I wanted to achieve, though.
  • Jim Scott
    March 17, 2019 at 9:46 pm
    I’m not familiar with C4D Lite so I wouldn’t have known what capabilities it was missing, but I’m glad you got it worked out.
