Explorer Not Showing Files Nor Folders
Posted by Debbie King on December 14, 2014 at 3:47 pmHi Everyone:
Has anyone ever had this issue? When I select Explorer the box comes up empty; no folders nor files are shown. I rebooted and reopened and the same issue occurred.
Any help would be greatly appreciated.
Best,
Debbie
Adrian Palmer replied 3 years, 11 months ago 9 Members · 17 Replies -
Francis S. dobos
December 14, 2014 at 6:33 pmHello Debbie,
‘No folders, no files’ as you wrote. But do you see the storage driver? Can you embed a screenshot?
Francis S. Dobos
Mark Barton
December 15, 2014 at 5:18 amWhat happens if you click the button that looks like two arrows pointing down (chevron) next to the empty path dialog (long empty rectangle)? Do you get a choice of drives? I suspect one of your drives is not responding quickly and it is not displaying anything until it gets a response from all the drives in your system. Is there an external drive you were using or I wonder if it was related to that combo BluRay device you were asking questions about. There is also a chance it is trying to bring back the last drive/path you used with that explorer dialog and it is having trouble finding it (i.e. a removable drive). Maybe one of these hints will get you a little closer to the solution.
Francis S. dobos
December 15, 2014 at 10:56 amDebbie, I agree with Mark’s proposal. Probably you have a hardware problem (connection) and the SV doesn’t see the proper drive. It seems to me this is not the fault of the SV.
Francis S. Dobos
Debbie King
December 15, 2014 at 6:49 pmHi Mark and Francis:
Thank you so much for responding.
I cannot see anything, but when I click the folder icon above, it opens the explorer for me to see and select files. I can only see the files if I click that folder icon. Nothing shows in Vegas.
Many thanks.
Best,
Debbie
Mark Barton
December 15, 2014 at 7:09 pmIt looks like the panel where the drives and folders would be displayed to navigate is collapsed (hidden from view). To the left where you see the Name column, can you hover your mouse over that vertical line and see if the mouse cursor changes to the two arrows pointing opposite ways and drag that line (frame boundary) to the right to expose the navigational panel? It should look similar to my screenshot.
Russ Froze
December 16, 2014 at 6:53 pmHello again Debbie King,
Have you tried typing in Alt+D,D
Russ Froze -
Mark Thompson
January 14, 2015 at 10:43 amDebbie,
if you still have this problem, here’s a couple of debugging tips:
Find the Folder where your start-up information is logged. On my box this is: C:\Users\zthom\AppData\Local\Sony\Vegas Pro\13.0where you need to replace “zthom” with your username. Also replace “13.0” with your version – “12.0” ?
In that folder there are two files of interest:
FileExplorer.log This contains a line for each startup. For example:======== 1/11/2015 12:22:22 PM: Created Window Successfully
======== 1/13/2015 12:00:55 AM: Created Window SuccessfullyThe above are successful startups, perhaps yours has some error information there?
IF there are reports of problems there look at file FileExplorer.settings . Whatever you do don’t edit/change this, perhaps copy it to another file. Then have a look. On my box this contains:
<?xml version="1.0" encoding="utf-8"?>
Your file should look much the same except should be different.Check that it is not pointing to a device that is no longer on your system (perhaps you used and then removed a USB drive).
David Kirshner
November 2, 2015 at 7:59 amWas this problem ever sorted? I am experiencing exactly the same issue. I have followed all of the instructions above, to no avail.
Mark Thompson
November 2, 2015 at 3:30 pmHi,
did you manage to find the Settings file?View > Windows Layouts > Default Layout ??
Have you got the very latest software? Plenty of free disk space on all relevant drives?
Has you drive layout changed recently?
Is this a new install ?
Was it all ok and then suddenly something happened? if so what was that?
I’ve tried to reproduce the problem but had no luck so far.
mark
