Activity Forums Adobe After Effects Explode image into a “new” image – a creation
  • Explode image into a “new” image – a creation
    Posted by Eric Holzapfel on August 20, 2012 at 5:01 pm
    Hello Forum,
    This is a great forum.
    I would like some suggestions on a possible workflow to accomplish the effect below.
    I have some video footage of playdoh that I would like to give the appearance of moving, etc.
    I would like to explode or morph (etc) a chunk of playdoh
    into a small child. The playdoh “turns in” to a small child.
    I am familar with Apple Motion, and Adobe After Effects. This will be a film, most likely
    on a DVD, and possible Youtube post. I was thinking that Adobe After Effects might be
    better for this than apple motion. I am using FCP 7. Should I create a couple of still images,
    and use those in a comp, masking or vignetting the playdoh. I would like to create an
    effect such that it looks like the playdoh is vibrating or squishing or moving is some manner,
    then all of a sudden it explodes, and presto changeo a small child has been born.
    I am thinking some form of particle generator, etc. Should I work with the video clip (which is more or less static) or create some still frames, and tweak in AE or Motion or Photoshop?
    Thanks for a helpful forum.
    Eric W. Holzapfel
    Final Cut Pro, Adobe After Effects, Photoshop
    Eric Holzapfel replied 14 years ago 1 Member · 0 Replies
  • 0 Replies
