Activity Forums Apple Final Cut Pro Legacy Explain what journaling means
  • Explain what journaling means
    Posted by Chris Poisson on December 11, 2005 at 2:05 pm
    At the suggestion of someone here, I got a utility called Coctail to maintain the OS, can anyone explain what journaling means, and why or why not to use it?
    Thanks.
    Have a wonderful day.
    Chris Poisson replied 20 years, 9 months ago 2 Members · 2 Replies
  • Andy Mees
    December 11, 2005 at 2:42 pm
    A journaling file system is a file system that logs changes to a journal (usually a circular log in a specially-allocated area) before actually writing them to the main file system … so, for example, if there was a power outage during a write operation, on reboot, the system needs only check that the main filesystem and journal are in sync (and if they’re not it can resync by applying the changes as per the journal)
    all this and much more at: https://en.wikipedia.org/wiki/Journaling_filesystem 🙂
  • Chris Poisson
    December 11, 2005 at 3:22 pm
    Thanks Andy.
