Activity Forums Apple Final Cut Pro Legacy Explain: Following Rendering Problem
  • Explain: Following Rendering Problem
    Posted by Jeremy Donaldson on February 11, 2009 at 10:29 pm
    Sometimes I go to render clips that need to be rendered on my timeline, but when I click Render>Only what needs rendering, nothing happens, but I can go and select each clip and do a Render Selected Video and it works. Usually Render only needed works fine, but sometime it does nothing, and I am trying to figure out what causes it to not want to render at times. Hope this makes since.
    Victor Perez replied 17 years, 6 months ago 3 Members · 2 Replies
  • Chris Borjis
    February 11, 2009 at 10:33 pm
    just hold down option+a to select all then option+r to render.
  • Victor Perez
    February 11, 2009 at 11:33 pm
    Usually under Sequence>Render I only have Needs Render (Video) and For Playback (Audio) checked when I am editing along and I use the shortcut Apple R to render what is selected as RED (Unrendered) in my timeline.
    Under Sequence>Render All I usually have them all checked and only use the shortcut Option R when I take a break, go to lunch or have more time to let everything render. I then click Shift A to select all clips in the timeline then Option R to render everything in it. Most of our clips have Color Correction, Moves, Resizes and if I hit Option R each time I will be spending more time rendering and less time working.
    Not being able to render may also occur because of a number of different things.
    Here are some that come to mind.
    If you have in and out marks on your timeline and your clip is outside the markers and not selected, it will not render.
    If the colored bar in Sequences>Render is not checked, that color line in your sequence will not render.
    I just highlight all clips I want to render and hit Apple R. As long as the color I want to render is checked in Sequence>Render I should be good to go.
    Thats all I can think of for now,
    Good luck,
    Victor
