Activity Forums Apple Final Cut Pro Legacy explain 32 bit floating point
  • explain 32 bit floating point
    Posted by Dale Larsen on June 15, 2010 at 10:13 pm
    can anyone put into simple terms an explanation of how/why 32 bit floating point comes into effect when outputting in certain codecs like DV, HDV, H 264.
    These codecs are 8 bit native, but under certain circumstances (I think it has to do with adding a filter like 3 way color corrector) they get rendered out in 32 bit.
    Is this true/false
    here is an article I found that got me on this path but at the same time has added a little confusion as well.
    https://www.kenstone.net/discussions/read.php?3,24626,24626
    any and all knowledge from the masters (thats you guys) would be appreciated.
    Dale
    Jeremy Garchow replied 16 years, 3 months ago 2 Members · 1 Reply
  • Jeremy Garchow
    June 15, 2010 at 11:36 pm
    It doesn’t get rendered to 32 bit, but rather processed in 32 bit.
    So 8 bit codec gets decompressed and any all effects get processed
    in float before getting compressed back to whatever codec your timeline is set to.
    It allows keeping the utmost image fidelity through the effects processing pipeline.
