Activity Forums Blackmagic Design expert AES question
  • expert AES question
    Posted by Pol on August 2, 2005 at 10:47 am
    I’ve done some research…. The SPDIF output on BMcards is essentially AES.
    So I bought a neutrik impedance transformer (NADITBNC) to transform the impedance from 75 (SPDIF) to 110 (AES).
    Now that does not work…on my digi beta machine from Sony. But it does work on another device that has AES input.
    What’s the difference? Is it a bit problem (digi beta 20bit) or is the signal to weak?
    Anyone please….
    Pol replied 21 years, 1 month ago 2 Members · 2 Replies
  • Peter Wiggins
    August 2, 2005 at 11:33 am
    Can you not use embedded?
    Peter
    https://www.peterwiggins.com
    Having a rest after working 6 weeks without a day off
  • Pol
    August 2, 2005 at 11:58 am
    I need seperate audio because we have a digital maximizer (TC-electronic) with AES input.
    I could use a SDI de-embedder but those devices are expensive.
