Activity Forums Adobe After Effects Experienced user – Problem with rotobrush, rendered video does not match with preview in composition – 1 frame offset
  • Experienced user – Problem with rotobrush, rendered video does not match with preview in composition – 1 frame offset
    Posted by Dalibor Mitic on November 13, 2018 at 11:36 pm
    Hello guys, i hope someone can help me with this weird problem.
    I am very experienced in using rotobrush and AE in general, and have done many rotoscoping projects, but this is first time i have come to this problem and i can not figure it out by myself.
    i am rotoing a horse and when i watch it in the composition frame by frame everything is perfectly aligned, but when i render it out i get completely different result, its exactly one frame offset backward. I have freezed roto, and made all adjustments to roto mate and refine edge mate.
    Here is how it looks in comp view https://prntscr.com/li1e4b
    Here is how it looks rendered https://prntscr.com/li1egh
    I have tried to offset the layer for this one frame forward and it renders normal but i have seeing it offseted in the AE prew, and when i render it all is perfectly aligned. Very weird…
    Did someone had similar issue?
    I am using AE CC 2014 on win 7
    Mark Whitney replied 7 years, 10 months ago 3 Members · 4 Replies
  • Mark Whitney
    November 14, 2018 at 5:56 am
    Can’t say I have but what are your output settings? Perhaps some missmatch on frame rate or something other than progressive got changed on your output module?
  • Mark Doctor
    November 15, 2018 at 12:46 am
    Very odd indeed? I also would suggest looking at the shutter settings, angle and phase.
    Greets Mark
  • Dalibor Mitic
    November 15, 2018 at 1:45 pm
    Thank you all for reply.
    I figured it out, it was nonstandard frame rate of source video, it was 30.249 and some frames was randomly get offset when video is rendered. Even on the rode which was done with masks.
    The solution was, i turned on preserve frame rate in advance settings in composition
    And also in render settings i told it to use exact frame rate of 30.249
    That fixed the issue and all was normally rendered.
  • Mark Whitney
    November 15, 2018 at 11:04 pm
    It’s always something with the math. What an odd framerate though. I’d certainly inquire why and be willing to be they didn’t even know.
