There are slightly cheaper ones available but these ones seem to be quite complete. and there are more expensive versions of the same ones that are rigged.
I would ask your client if they are OK with the quality of the model. This “quality” aspect won’t fall under the 3D company’s “100% quality” warranty though. Its all about whether the client feels its a reasonable and correctly detailed enough representation of the human body for their purposes (especially surgery). At this level of model it will be right enough for the 100% warranty but might not be right enough for the client.
In the end its a pretty good deal – there are a huge amount of models in there that separately would cost much much more.
A few things to check – especially for surgery:
Does the heart come apart? Are the lungs solid or do they have an interior? Are the intestines overlapping and one bend intrudes into another? – if all the bends were spline controlled you could unkink the whole thing but as a solid model you can be stuck and these overlaps will show if you do a cutaway. (try a bool by the way and see how the model reacts). Do the tube type things (aorta, arteries, intestines etc) have wall thickness or are they just shells?
Is there an interior to the mouth? Are the eye’s orbs or just a front cap? Are there eye muscles and optic nerve?(I’ve seen this left out sooo many times). Are the eyelids separate or attached to the “skin”? Do the ears have a canal and internal bones? Are all the bones in the foot there? (I’ve seen this incorrect many times too). Are the disks in the spine separate from the vertebrae?
