Activity Forums Apple Final Cut Pro Legacy Expanding the columns in the filters tab
  • Expanding the columns in the filters tab
    Posted by Neil Weaver on October 18, 2009 at 5:24 pm
    I’ve had a scan through the manual and the threads but can’t seem to find the answer to what I’m sure is a very simple issue.
    I’ve just bought magic bullet colorista and I can’t widen the parameters column in the filters tab so that I can see all three color wheels.
    If I hover the mouse in between columns, the cursor changes to one that normally lets you pull columns around, but it has no effect.
    Any ideas?
    Neil Weaver replied 16 years, 10 months ago 2 Members · 2 Replies
  • John Fishback
    October 18, 2009 at 6:02 pm
    You may have to expand the filter window so you can the use the control you mention to widen the column with the color wheels. You can drag the filter window to a new area on your monitor to expand it, or expand it in-place.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Neil Weaver
    October 18, 2009 at 6:07 pm
    I thought, I’d done that, but apparently not. What a numbnuts!
    Thanks John, instant fix!
