Activity › Forums › Adobe After Effects › expanding a jpeg. on the timeline
Posted by John Scott on February 23, 2010 at 6:48 pmHey there, I am using After Effects and need to add some bullet hits to a wall in some footage but the jpeg image when imported is only a few seconds long. how do I expand the time of the jpeg. once dropped into the timline
ThanksJason Vazquez replied 14 years, 6 months ago 4 Members · 7 Replies -
Nathan Rogers
February 23, 2010 at 7:24 pmThere are actually a couple of ways of doing this. The easiest is to grab the end bracket and drag it out to the desired amount of time. If you want it to be more exact, you can set the duration by selecting the times tab on the bottom left had corner of the timeline window.
Todd Kopriva
February 23, 2010 at 8:08 pmSee Trim, extend, or slip-edit a layer”.
putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment. -
John Scott
February 24, 2010 at 9:00 pmNot having any luck… I am using a jpeg and or png form Action Essentials…When I drag the jpeg to the timline or over my compestion frame it always ends up at the begining of my clip and its only 8 frames long. How do you make a jpeg longer? I tried stretching it but no go….I know I am missing the obvious here but I need help..
John -
Todd Kopriva
February 24, 2010 at 9:31 pmIt should work. Post a screenshot.
John Scott
February 24, 2010 at 9:53 pmOk I figured it out….I needed to do the “time stretch” command…didn’t knot it existed..found it…thanks..
Todd Kopriva
February 24, 2010 at 9:57 pm> Ok I figured it out….I needed to do the “time stretch” command…
That shouldn’t be necessary with a layer based on a single still image. You didn’t answer Dave’s question. Is this an _image sequence_?
Jason Vazquez
February 21, 2012 at 7:36 pmOk i am having a similar problem.. i bought action essentials 2 720 and i am tryin to input a ground crack… i place the layer on top of my footage and when i render or play it all it does is play a sequence of ground crack jpg’s that are in that file rather than the single ground crack and the action its suppose to preform… it doesnt go the “ground crack ” animation when played… all it does is cycle thru all the ground crack images that are in the file.. ive done homework and ive learned that “ground crack” for a hancock like effect is suppose to be in “png” format, but the pack i downloaded from video copilot is in jpg…. am i doin something wrong? PLEASE HELP!
