Activity Forums Apple Final Cut Pro Expand/collapse audio components
  • Expand/collapse audio components
    Posted by Mark Morache on November 1, 2016 at 11:14 pm
    I’m sure there’s probably a new workflow I need to learn and adopt, however I used to be able to collapse the components on all clips. I had it mapped to option C, and I used to be able to expand all clips where the audio is split.
    Obviously Apple thought they had a better way for me to edit, because these options are no longer available in the shortcut editor.
    What’s up with that?
    -Mark
    Mark Morache
    Evening Magazine, Seattle, WA
    Jeremy Garchow replied 9 years, 10 months ago 3 Members · 2 Replies
  • Bret Williams
    November 2, 2016 at 2:39 am
    I guess they want you to show audio lanes instead. Which is only useful if you’ve diligently marked all your roles correctly.
    _______________________________________________________________________
    https://BretFX.com Up to 60% off all plugins through 11/6!
  • Jeremy Garchow
    November 2, 2016 at 3:38 am
    [Mark Morache] “What’s up with that?”
    Expand splits seems to be totally gone.
    To collapse, you need to expand, then expand components, then collapse components.
    Or
    You could just expand components instead of expand, and show audio lanes instead of expand splits
