Activity › Forums › Apple Final Cut Pro › Expand dual mono without breaking apart clip items?
  • Expand dual mono without breaking apart clip items?
    Posted by James Culbertson on July 7, 2011 at 8:41 pm
    Is there a way to “expand audio/video” to be able to see both dual mono tracks without having to “break apart clip items”?
    Or a way to collapse audio/video once you have broken apart clip items (without having to compound the clip)?
    James
    James Culbertson replied 15 years, 2 months ago 3 Members · 8 Replies
  • 8 Replies
  • Tom Wolsky
    July 7, 2011 at 9:28 pm
    Making video and audio of a clip that’s broken into a compound clip apparently simply puts it back together again. It doesn’t behave like a compound clip, i.e. open into a separate timeline, and the audio can still be expanded and collapsed.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
    Coming in 2011 “Complete Training for FCPX”
    and “Final Cut Pro X for iMovie and Final Cut Express Users” from Focal Press
  • Tom Wolsky
    July 7, 2011 at 9:31 pm
    Actually forget that, it has a big drawback. The clip is limited in duration. You’re hosed, or wait for the upgrade.
    All the best,
    Tom
  • Mark Morache
    July 7, 2011 at 9:36 pm
    Limited in duration? How long?
    I’ve been looking for the best way to ride gain on two channels of audio. I generally just need to do this for as long as a soundbite. 20-30 seconds max.
    Really easy in FCP 7… Apple, you listening?
    Mark Morache
    Evening Magazine
    Seattle, WA
  • Tom Wolsky
    July 7, 2011 at 9:44 pm
    No, they’re not. Use feedback.
    All the best,
    Tom
  • James Culbertson
    July 8, 2011 at 4:43 am
    Just figure out that if I control click a compound clip, and choose “open in timeline” you get access to the handles again. If you extend the clip length in the separate timeline then go back to the main timeline you can trim the compound clip beyond the original in and out point.
  • James Culbertson
    July 8, 2011 at 5:03 am
    Just realized that “open in timeline” (from contextual menu) gives you access to dual mono without breaking apart clips.
  • Tom Wolsky
    July 8, 2011 at 9:24 am
    So you have to adjust the levels of the dual mono without hearing the other tracks?
    All the best,
    Tom
  • James Culbertson
    July 8, 2011 at 4:21 pm
    Not optimal for sure. But you could set the relative levels there than ride the mix of the two in the main timeline.
    Get it close than go back once you have “locked” the edit and break apart clips to finesse.
    Anyway, “don’t shoot the messenger” and all that…
