Activity Forums Adobe After Effects Expressions expand corner pin
  • Posted by Dan Sforza on July 26, 2010 at 8:59 pm
    Hello All,
    I am running into some problems with corner pin. I used Mocha for a planer track ( of a monitor ) and imported into AE. The effect I want is to fly through the footage into and through the tracked image. To do this created a precomp with elements in Z space, collapsed the transforms in the main comp, then applied the Corner Pin to the precomp. When I dolly through the comp using a camera everything works except the 3D elements in the precomp get cut off due to the corner pin effect. It seems I need a Lg precomp for this effect to work.
    Ive tried a bunch of solutions with no success.
    Is there a way to change the effective position of the pin.
    for instance (on a precomp thats 2048×1536)have the top left corner pin’s starting position at (512,384) position instead of (0,0) and so on with the other pins?
    Filip Vandueren replied 16 years, 2 months ago 2 Members · 1 Reply
  • Filip Vandueren
    July 26, 2010 at 11:27 pm
    Hi Dan,
    could you create some screenshots, it’s a bit complicated to follow what you’re saying.
    At it’s simplest, scaling a corner-pin to be larger than it is according to the keyframes can be done like described in this old post:
    https://forums.creativecow.net/readpost/227/251
    my solution back then involved calculating the average of the 4 corners, and then multiplying the difference so all points get pushed away from the center -> scaling up the corners
    you might need different ways to calculate th emidpoint, Dan pointed me in the right direction here:
    https://forums.creativecow.net/archivethread/2/518048
    there’s a lot more discussion and some expressions if you search the forum for corner pin
