Activity Forums Apple Final Cut Pro Exisitng Compound Clip Behavior when upgrade from 10.04 to 10.06
  • Exisitng Compound Clip Behavior when upgrade from 10.04 to 10.06
    Posted by Phil Coulloudon on November 5, 2012 at 8:19 pm
    How are Existing Compounds treated when upgrading from 10.04 projects into 10.06? I do see that the twirl down in upper left of clip is not there. Right click is only way I see to open a compound created in previous version and brought forward.
    But what about the impact on project size/performance and the blade results? Will existing compounds benefit from the new way compounds are treated? Copy / Paste / Blade, etc.
    -phil
    Adam Chesbrough replied 13 years, 10 months ago 3 Members · 6 Replies
  • Michael Garber
    November 5, 2012 at 9:21 pm
    It does not upgrade pre-existing compounds. In order to get FCPX to treat them in the new fashion, you should break open your current compounds and then make them again.
    I haven’t done any complex editing with compounds yet, but from what I understand, the issues when blading them should be fixed.
    Michael Garber
    5th Wall – a post production company
  • Phil Coulloudon
    November 5, 2012 at 9:37 pm
    Thanks for the reply….
    So I assume performance issues will remain until I break apart pre-existing compounds and create new ones?
    -philc
  • Michael Garber
    November 5, 2012 at 9:51 pm
    most likely, yes.
    Michael Garber
  • Phil Coulloudon
    November 5, 2012 at 10:12 pm
    Hmmm, ok thanks. I have at least a couple 20min projects that contain lots of compounds which need to be brought forward to 10.06. Seems I need to set aside some time to conform.
    -philc
  • Adam Chesbrough
    November 6, 2012 at 2:55 pm
    I am no longer able to break apart compound clips in 10.0.6, this is an issue as I sometimes keep music on the timeline and need to cut to the beats. Anyone having this issue as well?
    Macbook Pro Retina: 2.6GHZ i7, 16GB RAM 1600MHz DDR3, GT 650M 1GB RAM
    Hackintosh (Sandy Bridge): i5 2500, 16GB 1333MHz DDR3, Nvidia GT640 2GB RAM
    OWC 4TB RAID0 (using esata)
    Tempo SATA Pro ExpressCard/34 (6Gb/s)
    Echo ExpressCard Pro Thunderbolt Adapter
  • Adam Chesbrough
    November 6, 2012 at 2:56 pm
    this is an option just not under right click anymore. shift+cmd_G.
    Please ignore
