Activity Forums Apple Final Cut Pro Legacy ExFAT – ProDrive woes…
  • ExFAT – ProDrive woes…
    Posted by Tad Newberry on April 16, 2011 at 9:57 pm
    i sent (3) ExFAT formatted drives to a client with a PC. he sent them back saying he couldn’t read any of them. i tested them today on my PC’s. Here is what i found – the (2) Passports showed up fine in my Netbook PC running Windows 7 Starter. But plugging in the SimpleTech ProDrive yielded nothing…though when i would pull the USB cable out of the netbook it would ask if i wanted to format the drive (that was no longer connected).
    plugging them all into my Mac, it read the Passports fine, but the ProDrive asked to be initialized. So i went to Disk Utility, did a verified (which said it needed to be repaired), it repaired fine, then showed up fine on the desktop. Files intact. Took the same USB cable out of Mac into the Netbook…nothing. USB back to the Mac – and it asked to be initialized again! Verified, repaired, and it showed up fine again.
    Anyone know what gives here??? I’m very confused as to how to get him some drives where he can at least see the files, though i know he won’t be able to play all the QTs, he should be able to know which files are there and can read image files and docs.
    thanks for helping out a bonehead!
    __________________________
    FCS3
    2.66 GHz Quad-Core Mac Pro
    6GB RAM
    NVIDIA GeForce GT 120
    …and a few TeraBytes o’ storage
    (then it’s on to PetaBytes, ExaBytes and MosquitoBytes!)
    Tad Newberry replied 15 years, 4 months ago 10 Members · 22 Replies
  • 22 Replies
  • Jeremy Garchow
    April 16, 2011 at 10:23 pm
    Purchase MacDrive for them and use HFS (Mac) formatted drives:
    https://www.mediafour.com/products/macdrive
    Jeremy
  • David Roth weiss
    April 16, 2011 at 10:58 pm
    I agree with Jeremy. Having tired every alternative, the combination of Mac formatted drives and MacDrive is the only seamless solution that works all the time on the PC side.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    https://www.drwfilms.com
    A forum host of Creative COW’s Business & Marketing and Apple Final Cut Pro forums. Formerly host of the Apple Final Cut Basics, Indie Film & Documentary, and Film History & Appreciations forums.
  • Tad Newberry
    April 16, 2011 at 11:04 pm
    Alrighty…that sounds good, but i’m just curious why the PC is seeing the Passport drives with no problem, but not the ProDrive…and that other funky thing with the ProDrive having to be verified and repaired every time it is taken from the PC to the Mac???
    FCS3
    6GB RAM
  • Jeremy Garchow
    April 16, 2011 at 11:13 pm
    Gremlins.
  • Tad Newberry
    April 17, 2011 at 12:31 am
    I realize formatting in DOS yields the 4 GB limit on file size, so what happens if you’re trying to transfer a 10GB file to a DOS drive? Does it only copy 4 GB of it, or is is just not playable from that drive, yet able to transfer/copy back to another drive later? Just wondering for other clients who probably won’t have MacDrive…also, with MacDrive…is it something I put on the drives i send them or do they have to have it on their PC…or both?
    FCS3
    6GB RAM
  • Jeremy Garchow
    April 17, 2011 at 12:40 am
    [tad newberry] “Just wondering for other clients who probably won’t have MacDrive…also, with MacDrive…is it something I put on the drives i send them or do they have to have it on their PC…or both?”
    It’s an application that runs on a PC:
    https://www.mediafour.com/products/macdrive/howdoesitwork
    As far as Fat32, just don’t bother. Files over 4GB don’t work.
    Jeremy
  • Zane Barker
    April 17, 2011 at 1:04 am
    [tad newberry] “I realize formatting in DOS yields the 4 GB limit on file size, so what happens if you’re trying to transfer a 10GB file to a DOS drive?”
    You must mean Fat23 format. DOS is on old old old os not a drive format.
    If you tried to copy a file larger then 4GB onto a Fat32 formatted drive you will get an error message saying you cannot copy the file to the drive. to get any file onto that drive it would need to be less then 4GB in size.
    **Hindsight is always 1080p**
  • Steven Gladstone
    April 17, 2011 at 1:24 am
    I’m not sure about the EXfat drives (or even what that is – FAT32?). I use MAcdrive, and actually ran into problems which were all traceable to windows. What happened was on the Windows machine, the Automount file/function whatever was corrupted. No drives would automount, and this caused major headaches (and rendered LaCie ruggedized drives useless and needing to be reformatted, although not WD drives)
    Sounding a little familiar????
    So I have a feeling that the clients computer might have an issue – although try telling them that.
    Steven Gladstone
    https://www.gladstonefilms.com
  • Rafael Amador
    April 17, 2011 at 9:24 am
    [tad newberry] “i sent (3) ExFAT formatted drives “
    That is a pen-drive format.
    FAT-32 was the format you where looking for.
    rafael
    http://www.nagavideo.com
  • Tad Newberry
    April 18, 2011 at 3:10 am
    okay…here’s my dumb question (or two): is “FAT-32” the same as “MS-DOS (FAT)”? If not, where/how do i format in FAT-32, because Disk Utility does not offer it as an option…and does FAT-32 allow for files bigger than 4GB?
    FCS3
    6GB RAM
Page 1 of 3
