Activity Forums Maxon Cinema 4D Excluding light from an object
  • Excluding light from an object
    Posted by Dean Chapman on September 3, 2010 at 2:43 am
    I can’t seem to figure out how to exclude a light’s affect on one particular object in my scene…
    I’ve tried adding a compositing tag to the light, and dropping my object into the exclusion area, but nothing happens.
    I built my lights by creating a plane, and simply adding a material with %150 luminance….and using the compositing tag to uncheck “seen by camera”. Is there something i’m missing here?
    thanks,
    dean
    Tim Shetz replied 16 years ago 2 Members · 1 Reply
  • Tim Shetz
    September 3, 2010 at 3:41 am
    If you go to the SCENE tab of your light, you can drag your object into the EXCLUDE box there. That should work.
    Tim
    Tim Shetz
    C4DTraining.com
