Activity Forums Square Box CatDV Exclude watchfolder file from being catalogued?
  • Exclude watchfolder file from being catalogued?
    Posted by Deleted User on July 10, 2015 at 8:20 pm
    I use Adobe Media Encoder to create master OP1a files of timelines. The export location is a CatDV watchfolder. I don’t need the .xmp file that accompanies the .mxf file. How can I tell the worker script to exclude the .xmp file?
    thanks
    Lee
    Lee
    SAMDOG Digital Post
    Calgary, Alberta based Post Production Specialist & visual problem solver. Fluent in Avid, Premiere Pro, After Effects, yada, yada, yada.
    Available for hire.
    Calgary, Alberta YYC · tinyurl.com/6vgfa3f
    Deleted User replied 11 years, 1 month ago 2 Members · 2 Replies
  • Bryson Jones
    July 12, 2015 at 5:10 am
    Under the conditions tab, “Exclude” in the manual they discuss the various things you can exclude but *.xmp should get you started.
    bryson
    bryson “at” northshoreautomation.com
  • Deleted User
    July 27, 2015 at 10:01 pm
    Thanks Bryson.
    Lee
    SAMDOG Digital Post
    Available for hire.
