Activity Forums Adobe After Effects Exclude effects on a layer within a composition
  • Exclude effects on a layer within a composition
    Posted by Chris Thomas on February 7, 2017 at 5:28 pm
    I have just completed a large project involving a few thousand layers and nearly 100 precomps. The client has just requested a global color shift—which would normally be no problem.
    However, it is a problem—because this spot contains video footage all throughout the piece that (obviously) needs to be excluded from the color shifting. Is there any way to force a layer within a comp (or deep within many comps) from receiving any effects? Even if that effect is on its parent composition?
    I know there are other solutions involving duplicating my comps and basically separating out the video from the rest of the footage. But if you saw my project file, you’d see why that’s almost laughable. Plus, god forbid the client needs to edit the animation and now I’m making the adjustments across multiple comps.
    I can’t find any solutions out there… would love it if someone had some insight!
    Walter Soyka replied 9 years, 6 months ago 2 Members · 1 Reply
  • Walter Soyka
    February 7, 2017 at 6:58 pm
    What about applying an offsetting effect to the video layers? Not the Offset effect, but something that will reverse the global transformation you will apply on top of the video. For example, if you were globally increasing the exposure one stop, how about decreasing the exposure one stop on each video layer?
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
