Activity Forums DaVinci Resolve Exclude a clip from time-line nodes
  • Exclude a clip from time-line nodes
    Posted by Johan Windh on December 19, 2022 at 1:12 pm
    Hi. I’ve got some text which I don’t want to have the halation FX on (applied with timeline node). I’m looking for a way to exclude the text from it.
    I’ve tried to make a Compound clip, but if I remove any timeline-nodes from the Compound, they also disappear from the timeline embedded.
    Trying with a Fusion clip, there seems to be no way to even create nodes in the timeline mode.
    Any help here would be greatly appreciated.
    Johan Windh replied 3 years, 8 months ago 2 Members · 2 Replies
  • Michael Gissing
    December 19, 2022 at 10:13 pm
    The timeline adjustment node on the Color page is designed specifically to affect the whole timeline. The easiest way to affect the timeline but not title elements is to place an adjustment layer on a track between all your titles and the clips underneath. Apply the Halation effect to the adjustment layer and it will affect everything below the adjustment clip. This is the easiest way to create an affect across the whole timeline with the ability to exclude certain clips simply by repositioning them above that layer.
    The other way which plays into my usual deliverables is to export a textless version and drop that into a new timeline and add all the text elements before outputing the texted version. The Halation is baked into the textless and the text is unaffected.
    Third method is to edit your textless timeline into a new timeline, with the text then added. This way you can go back to the original timeline and any changes are then translated in the new timeline.
  • Johan Windh
    December 21, 2022 at 7:36 am
    Many thanks Michael.
