Activity Forums Apple Final Cut Pro Legacy Exclamation Point in a Yellow Triangle
  • Exclamation Point in a Yellow Triangle
    Posted by Heringji on September 13, 2006 at 4:04 pm
    What is that thing? It appears in my Viewer. When i don’t have a clip open the Viewer has a similar (but different) green circle with a check-mark in it. I’m also getting green and red zebra stripes on the white areas when I do have a . Can someone tell me how to get rid of these?
    Jill
    Bret Williams replied 20 years ago 4 Members · 3 Replies
  • Mantrafilm
    September 13, 2006 at 4:15 pm
    go to view> range check and turn off excess luma etc…
    You probably hit a shortcut by accident
  • Kevin Monahan
    September 13, 2006 at 4:31 pm
    Prob’ly an ex-windoze guy.
    CNTRL + Z
    When you meant….
    CMD + Z
    It’s a toggle.
    Kevin Monahan
    Take My FCP Master’s Workshop!
    fcpworld.com
    Pres. SF Cutters
  • Bret Williams
    September 13, 2006 at 5:27 pm
    Yep. That’s the ex-windows guy detection. Check mark if you’re ok, and an exclamation point if it thinks you’re some sort of spy.
