Activity Forums Apple Final Cut Pro Exclamation Mark on red background and effect symbol in FCP X 10.0.6
  • Exclamation Mark on red background and effect symbol in FCP X 10.0.6
    Posted by Anna Possberg on November 16, 2012 at 8:55 pm
    Hi everybody,
    some clips in my viewer display an exclamation mark on red background (see photo) although in the timeline the thumbnail shows the image and also the correspondent clip in the event plays normally.
    What could be the problem? Some days I added some color filters (levels and curves from nattress) – if they are corrupt what should I do in future to prevent this?
    Thomas Frank replied 13 years ago 2 Members · 1 Reply
  • Thomas Frank
    August 17, 2013 at 2:59 pm
    It is possible that the effects that you added is deleted or not installed anymore.
    Go in the inspector and toggle the effects off.
    Also from your name it sounds you are form Germany, if that is the case I know a buddy of my that is located in Germany that is a crack with FCPX and speaks German.
