Activity › Forums › VEGAS Pro › exchanging ram
  • Nigel O’neill
    June 15, 2011 at 9:33 am
    Does exchanging 4GB RAM with 8GB RAM will visibly improve my workflow in Vegas 10 64-bit? Is it worth bothering?
    Provided your motherboard and version of Windows x64 supports it, yes. Given the low cost of RAM nowadays, I would recommend installing between 12-16 GB.
    It will not improve your workflow per se, but it will make swapping between programs speedier, plus you can run multiple instances of Vegas if needed. e.g. recently I was able to simultaneously render 3 x 60 minute HDV projects using 2 pass VBR render settings on my system.
    My system specs: Intel i7 970, 12GB RAM, ASUS P6T, Vegas Pro 10 (x32/x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
  • Stephen Mann
    June 15, 2011 at 2:40 pm
    And you can RAM Preview longer regions.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
