Activity Forums Avid Media Composer “Exception: Failed to Initialize audio hardware.”
  • “Exception: Failed to Initialize audio hardware.”
    Posted by John Castelli on January 17, 2009 at 2:56 pm
    Hi all,
    Recently I my computer died and I had to get a new system (I love warranties!), but this time when I installed avid, it always stops its start up process and initializing audio. An error pops up that says “Exception: Failed to Initialize audio hardware.” On my last computer Avid worked flawlessly with Soundblaster Audigy 2, however, my new computer came with SoundBlaster X-FI, and it does not seem to get along with it. Any ideas on how to fix it?
    John
    John Castelli replied 17 years, 7 months ago 3 Members · 3 Replies
  • David Braswell
    January 19, 2009 at 8:15 pm
    If your system came from a qualified Avid dealer make him fix it.
    Didn’t think it did :-D, so… make sure the SB card is set as the preferred playback/record device. And check the bios to make sure no onboard audio cards are enabled. You may also be able to disable onbaoard cards within “Device Manager”. If none of the above work, you may want to borrow or buy a $27 Audigy and try it.
  • Neil Ryan
    January 20, 2009 at 5:29 am
    What OS version are you running?
    Neil Ryan
    Post Production Protagonist
  • John Castelli
    January 20, 2009 at 6:15 am
    Windows XP service pack 3. My last system was XP service pack 2
