Activity › Forums › VEGAS Pro › Exception Error when nesting veg projects.
  • Exception Error when nesting veg projects.
    Posted by Frank Manno on August 26, 2005 at 6:37 am
    I’m working on a project that has 4 veg (nested) files in it and lots of clips on the timeline.
    Project is around 30 mins in length and the nest files are around 2 hrs in total. I’ve worked on projects like this a fair bit with no problems in the past.
    Things are running well until I try to import a 5th veg file to nest. I keep getting an exception error and vegas terminating with a message. The message is a bunch of numbers eg’0x00008767656′ and it says ‘Memory could not be read’.
    The 5th veg file I’m trying to nest opens up nicely in my other vegas projects. Everything seems like it’s in order.
    Has anyone else experienced such problems when nesting large-ish veg files?
    Am using 1 gig RAM.
    -Frankie
    Frank Manno replied 21 years, 1 month ago 2 Members · 2 Replies
  • Edward Troxel
    August 26, 2005 at 1:39 pm
    What version of Vegas (6a/6b)? Are you loading that veg as nested in the other tests?
    Edward Troxel
    JETDV Scripts
  • Frank Manno
    August 26, 2005 at 2:26 pm
    Vegas 6.0b and yes, am loading that veg as nested in other tests.
    COuld it be possible that I’m simply loading too many veg files for nesting and Vegas can’t handle it and it’s driving everything bonkers? I’m using up to 5 veg files to nest in a project each containing around 100-150 clips and each around 30mins in length. Is that considered a real heavy load?
    Here’s the error I’m getting:
    Sony Vegas 6.0
    Version 6.0b (Build 115)
    Exception 0xC0000005 (access violation) READ:0x44C IP:0x645166
    In Module ‘vegas60.exe’ at Address 0x400000 + 0x245166
    Thread: VideoCache ID=0xF48 Stack=0x355F000-0x3560000
    Registers:
    EAX=00000000 CS=001b EIP=00645166 EFLGS=00010246
    EBX=0000001c SS=0023 ESP=0355f788 EBP=001f6530
    ECX=00000000 DS=0023 ESI=00000000 FS=003b
    EDX=001f653c ES=0023 EDI=69c7c340 GS=0000
    Bytes at CS:EIP:
    00645166: 8B 81 4C 04 00 00 74 1D ..L…t.
    0064516E: 85 C0 75 17 0F B7 41 12 ..u…A.
    Stack Dump:
    0355F788: 0065C2B9 00400000 + 25C2B9 (vegas60.exe)
    0355F78C: 00000000
    0355F790: 008DD1B0 00400000 + 4DD1B0 (vegas60.exe)
    0355F794: 00000003
    0355F798: 00000000
    0355F79C: 69C7C340 68B40000 + 113C340
    0355F7A0: 00000000
    0355F7A4: 69C7C338 68B40000 + 113C338
    0355F7A8: 80000000
    0355F7AC: 00000000
    0355F7B0: 00000000
    0355F7B4: 0000001C
    0355F7B8: 0065CB26 00400000 + 25CB26 (vegas60.exe)
    0355F7BC: 0433F4C8 04160000 + 1DF4C8
    0355F7C0: 00150CB0 00140000 + 10CB0
    0355F7C4: 69C7C340 68B40000 + 113C340
    > 0355F844: 00652519 00400000 + 252519 (vegas60.exe)
    0355F848: 001F6530 00140000 + B6530
    0355F84C: 0433F4C8 04160000 + 1DF4C8
    0355F850: 00150CB0 00140000 + 10CB0
    0355F854: 00000000
    > 0355F870: 00653456 00400000 + 253456 (vegas60.exe)
    0355F874: 69C7C330 68B40000 + 113C330
    0355F878: 001F6530 00140000 + B6530
    0355F87C: 00187AF8 00140000 + 47AF8
    0355F880: 00000000
    > 0355F888: 00653408 00400000 + 253408 (vegas60.exe)
    0355FFF0: 00000000
    0355FFF4: 0056D990 00400000 + 16D990 (vegas60.exe)
    0355FFF8: 0097A63C 00400000 + 57A63C (vegas60.exe)
    0355FFFC: 00000000
    And in -other- programs after the above error I may get the following:
    The instruction at “0x01cc6039” reference memory at “0x6c617284″. The memory could not be ‘read”.
    -Frankie
