Activity Forums VEGAS Pro Exception error when importing AAF file. Vegas Pro 12.0.563
  • Exception error when importing AAF file. Vegas Pro 12.0.563
    Posted by Ross Wissbaum on May 8, 2013 at 9:01 pm
    Imports into Vegas Pro 10 with no problems.
    Exception Message: startIndex cannot be larger than length of string.
    Parameter name: startIndex
    Stack Trace: at System.String.InternalSubStringWithChecks(Int32 startIndex, Int32 length, Boolean fAlwaysCopy)
    at VegasScripts.VegasCommon.GetImportMediaPath(String pathInImportedFile, List`1 mediaLocations)
    at VegasScripts.AafImporter.ImportClips(AafFile aafFile)
    at VegasScripts.AafImporter.Import(String fileName, Vegas vegas, LogCallback log, Action createUndoBlock, Action disposeUndoBlock)
    at VegasScripts.ProjectInterchangeImporter.HandleInvokedInternal(String openDialogName, String openDialogExt, String undoBlockName, IImporter importer)
    Stephen Mann replied 13 years, 4 months ago 2 Members · 1 Reply
  • Stephen Mann
    May 9, 2013 at 3:10 am
    Exception Errors are almost always a driver issue. Was Vegas 10 on a 32-bit system and Vegas 12 on a 64-bit system? You don’t have any Codec Packs installed, I hope.
    As a workaround, do you still have the Vegas 10 system? If the AAF file imports into Vegas 10, then encode the file into a intermediate format to load into Vegas 12.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
