Activity Forums VEGAS Pro Exception Error in Vegas 5
  • Exception Error in Vegas 5
    Posted by Andrew Jezierski on January 18, 2007 at 3:21 am
    Is there any way to rescue this file? I’ve tried to look for a back up file but the latest one is missing the last few days of work. I had a problem that I couldn’t get out of selection mode in the trimmer, so I saved the project and closed Vegas. Now when I try to open the project it loads (100% 1 of 5) and shows error message dialog. After clicking OK the application closes. Here are the detail of the error:
    Sony Vegas 5.0
    Version 5.0a (Build 134)
    Exception 0xC0000005 (access violation) READ:0x154 IP:0x4E38D7
    In Module ‘vegas50.exe’ at Address 0x400000 + 0xE38D7
    Thread: GUI ID=0x9C8 Stack=0x68000-0x130000
    Registers:
    EAX=09300ef0 CS=001b EIP=004e38d7 EFLGS=00210202
    EBX=07473b88 SS=0023 ESP=00068db4 EBP=00000002
    ECX=00000154 DS=0023 ESI=00000000 FS=003b
    EDX=00000154 ES=0023 EDI=00000000 GS=0000
    Bytes at CS:EIP:
    004E38D7: 8B 32 89 74 24 28 8B 4A .2.t$(.J
    004E38DF: 04 89 4C 24 2C 8B 42 08 ..L,.B.
    Stack Dump:
    00068DB4: 00000019
    00068DB8: 00000000
    00068DBC: 0FEC4B48 0FB00000 + 3C4B48
    00068DC0: 07473B88 07370000 + 103B88
    00068DC4: 00000000
    00068DC8: 07477CA8 07370000 + 107CA8
    00068DCC: 07477688 07370000 + 107688
    00068DD0: 074782C8 07370000 + 1082C8
    00068DD4: 00000002
    00068DD8: 00000002
    00068DDC: 00000216
    00068DE0: 0110005C 01000000 + 10005C (vegas50k.dll)
    00068DE4: 0110005B 01000000 + 10005B (vegas50k.dll)
    00068DE8: 00000217
    00068DEC: 004EBB7D 00400000 + EBB7D (vegas50.exe)
    00068DF0: 0B011CCC 0AF60000 + B1CCC (qt5plug.dll)
    > 00068E04: 0B011CCC 0AF60000 + B1CCC (qt5plug.dll)
    > 00068E08: 77F17AD9 77F10000 + 7AD9 (GDI32.dll)
    00068E0C: 07473B88 07370000 + 103B88
    00068E10: 00000000
    00068E14: 00000019
    > 00068E4C: 004EC77E 00400000 + EC77E (vegas50.exe)
    0012FFF0: 00000000
    0012FFF4: 00000000
    0012FFF8: 007287E0 00400000 + 3287E0 (vegas50.exe)
    0012FFFC: 00000000
    Andrew Jezierski replied 19 years, 8 months ago 2 Members · 2 Replies
  • Edward Troxel
    January 18, 2007 at 3:35 pm
    The first thing I would try is moving all the media so that the project can’t find it. Then see if it will open with “Ignore Missing Media”. Then you can start adding the media back in one piece at a time until you either find the offending media OR everything is working again.
    I know it won’t help now but it could for the future… The “Save Veg” tool in Excalibur was designed exactly to prevent this from happening. When you save with that tool, it will save the project THREE times – two of them with date/time appended to the file name allowing you to easily go back one revision or several days as needed.
    Edward Troxel
    JETDV Scripts
  • Andrew Jezierski
    January 19, 2007 at 7:14 pm
    Thanks. Fortunately I found finally a back up file that was only few hours old so was able to redo stuff relatively easy. Since then I saving my file every few hours with different names – doing it manually for now. Excaliber is on my wish list.
