Activity › Forums › Avid Media Composer › Exception: cannot access the AMA media stream plug in to play this clip
  • Exception: cannot access the AMA media stream plug in to play this clip
    Posted by Alberto Veloso on May 24, 2020 at 3:40 pm
    Hello! I’m a newbie to Avid Media Composer First, and I just recently upgraded my software to 2020.4 from 2019.12 (on Mac). When I did, however, I learned that two project files I started in the previous software don’t work right any more. I get the message “Exception: cannot access the AMA media stream plug in to play this clip.” What’s strange is that if I re-import the footage, I can play it just fine, but the new footage doesn’t link up to the clips in the timeline, so I would lose all my cuts ☹ Has anyone encountered this before? Any advice?
    Alberto Veloso replied 6 years, 3 months ago 2 Members · 6 Replies
  • Michael Phillips
    May 24, 2020 at 8:41 pm
    2020.4 introduced the QuickTime AMA replacement from earlier versions. Your media is still using the old plug-in and as you’ve noticed you can relink again in with the new new. You will have to relink all your media and do a “relink to selected”. There may be other methods but that is always my fallback/failsafe method. Highlight all your clips, then your sequence, right-click sequence, choose “relink to selected” and from there I would suggest looking for tutorials on relinking via good ol’ Google.
    Michael
  • Alberto Veloso
    May 25, 2020 at 1:18 am
    Hello Michael,
    Thank you for the reply, and your help. The QuickTime AMA replacement plug-in makes perfect sense as to the root of the problem, which is causing me more than a few grey hairs! In researching the problem, I did see some recommendations to relink the media, and that makes the most sense to me, but maybe because I’m a newbie, I can’t quite seem to figure out how to do it. For example, when I did the steps you suggested (select clips, select sequence, right click), I do see a “Link files” option, but it’s greyed out and un-chooseable. I haven’t seen a “relink to selection” option. Could you explain a little bit more how you do it?
    Thanks again for all your help so far.
    Alberto
  • Michael Phillips
    May 25, 2020 at 1:39 am
    The “relink to selected” is a subset of option in the “Relink” selection when right-clocking.
    MIchael
  • Alberto Veloso
    May 28, 2020 at 12:49 am
    Hi Michael,
    Still can’t seem to get to that menu ; / The “Relink files” button is always greyed out, but I’m sure that’s what I have to do and I’ll keep working on it till I figure it out.
    Thanks for all your help!
    Alberto
  • Michael Phillips
    May 28, 2020 at 2:23 pm
    You are looking for the “Relink” command. “Relink to Selected” is inside the dialogue window once opened:
    1. Highlight all the new master clips
    2. Highlight the sequence
    3. right-click on sequence
    4. Select “Relink”
    Maybe try this?
    https://www.youtube.com/watch?v=e1_yIZzM1JE
    Michael
  • Alberto Veloso
    May 29, 2020 at 3:28 pm
    Hi Michael,
    Thanks for the video! I can across it before and a few others about relinking, but the weird thing is that I don’t seem to have the same “Relink” button this video and the others have. It’s totally missing! You can see here: https://www.dropbox.com/s/03sywxp7svgbhzt/Relink%20Button%20Missing.png?dl=0
    It should be right about “Modify” but it’s not there. I do have “Relink to files”, but that is always greyed out. What’s worse, I’ve been googling the “missing Relink button” and no one else seems to have that problem. It’s a strangle little mystery 🙁
