Activity Forums Avid Media Composer Excel Magic button
  • Excel Magic button
    Posted by Greg Cohan on January 28, 2016 at 8:45 pm
    lets say I have a music library of 10,000 cues. These are all imported.
    In a separate excel doc I received the list of cues that include info I would like in the avid. Mostly searchable keywords I would generally put in a “Comments” column.
    the doc doesn’t have a start or end TC. But because these are aif imports I’m pretty sure they all start at 00:00 TC. Just no easy way to add an end tc.
    Any easy way of getting this meta data into the already imported cues or creating a batch list to re batch?
    I’m pretty sure I know the answer here but the idea of forcing someone to copy and past 10,000 times seem mean and cruel.
    Andrew Kimery replied 10 years, 7 months ago 3 Members · 4 Replies
  • Michael Phillips
    January 29, 2016 at 12:16 am
    Is the info embedded in the music cues by chance? If so, I developed an AMA plug-in that brings in all that metadata and will generate cue sheets from an AAF for an affordable $25!
    https://www.mus-id.com/
    If not, you can try exporting a TAB from from the bin after an import that includes START and END timecodes as well as TAPE and SOURCE FILE – and do the column copy process in Excel to make a new ALE file that you can merge back into your existing clips.
    Michael
  • Greg Cohan
    January 29, 2016 at 12:31 am
    I use Mus-ID all the time for bringing in our needle drop cues(which have the embedded metadata)
    It has made organizing our library of well over 200,000 cues much better.
    It is the originally composed cues we get that are not embedded… Boo 🙂
    I’ll try the Tab D list though I have never gotten that to work right.
    Also I just put a bunch of PA’s at producer station and am making them copy past everything 🙂
  • Michael Phillips
    January 29, 2016 at 4:20 pm
    I think you’ll have to do the import/export/merge process in order for Media Composer to give you the exact Start, End, and duration for each of the cues. Should be fairly quick to do with some column copy/pasting in Excel.
    Michael
  • Andrew Kimery
    January 30, 2016 at 10:24 pm
    [Greg Cohan] “I’m pretty sure I know the answer here but the idea of forcing someone to copy and past 10,000 times seem mean and cruel.
    That still sounds better than listening to 5,000 SFX and adding unique descriptions of them to a Comments column… 😉
