Activity Forums Adobe After Effects Exceeding Maximum Values on Effect Parameters
  • Exceeding Maximum Values on Effect Parameters
    Posted by Joseph Simons on December 5, 2012 at 8:33 pm
    Greetings, cows!
    I am working on an animation that involves using the ‘Spherize’ effect. The radius setting only allows a user to input a value of 2500.0 units or less. I understand that maximum value limits are common in attributes to LOTS of effects for a variety of reasons. Is there any way to override the maximum values for this (or any) effects, so that I could, for example, input a value of 3000+?
    I’ll be more than happy to provide more details regarding the project/process if necessary. Thanks in advance!
    Roland R. kahlenberg replied 13 years, 9 months ago 4 Members · 5 Replies
  • Chris Wright
    December 6, 2012 at 2:36 am
    could you move the camera closer or make other relative objects smaller?
  • Joseph Simons
    December 6, 2012 at 2:53 pm
    The shot involves zooming out from a close up of a city street plan to reveal the whole planet. The problem with simple camera tricks are that I need to use collapse transformations to preserve the quality of my vector file while zoomed most of the way in. Scaling/moving the camera closer distorts the relationship of the image and the effect in an unnatural way.
    I was just wondering if it was possible to override those settings, as my tests have proved that it would be an effective solution (if I can overcome the hurdle of the maximum parameter).
    Thanks again.
  • Todd Kopriva
    December 6, 2012 at 6:12 pm
    No, there is no way to override the maximum setting set for a parameter within an effect. The best that you can do for the long run is to submit a feature request explaining what change you want and why:
    https://www.adobe.com/go/wish
    After Effects team blog
  • Joseph Simons
    December 6, 2012 at 10:23 pm
    Hmm, disappointing, but thanks for the reply nonetheless.
    Is there a way I can reprogram the plugin to boost the max value manually? Can I do this through the plugin manager?
  • Roland R. kahlenberg
    December 7, 2012 at 7:26 am
    You should be able to mimic and accentuate the max. values of the Spherize effect with Bezier Warp.
    Here’s an image showing the default settings of Bezier Warp in the Comp Panel –
    Here’s an image showing Bezier Warp setup to mimic a spherize effec –
    And here’s one showing Spherize applied once
    Here’s Spherize, applied twice (duplicated with each instance set to a Radius of 2500)
    Your viable options are to apply Spherize twice, ie duplicate the effect or use the Bezier Warp effect.
    HTH
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects ACE/ACI (version 7)
