Activity Forums VEGAS Pro Excalibur 4 Multi-Cam update
  • Excalibur 4 Multi-Cam update
    Posted by Edward Troxel on June 15, 2005 at 2:23 pm
    For all users of Excalibur 4, Vegas 6b has added a new ability that allows switching cameras to be done without stopping playback of the timeline. After weeks of testing, I am now ready to allow anyone using Excalibur 4 and Vegas 6b to use this new functionality.
    DO NOT use this file in Vegas 5 and if you are using 6.0 or 6.0a, upgrade to 6.0b before using this file.
    Download the following file:
    https://www.jetdv.com/scripts/ExVegasUtils.dll
    This file should be copied to the Vegas 6.0Script MenuExcalibur4 folder and will replace an existing file. Once this file has been replaced, you will no longer need to stop the timeline playback to switch cameras. There WILL be a slight pause as the camera switches but playback will automatically continue.
    Edward Troxel
    JETDV Scripts
    Edward Troxel replied 21 years, 3 months ago 2 Members · 3 Replies
  • Peter C. goswick
    June 15, 2005 at 4:02 pm
    I get an error when trying to get this file
  • Peter C. goswick
    June 15, 2005 at 4:07 pm
    Something like:
    Application has generated an exception that could not be handled.
    Process id=0x5fc (1532) Threead id=0x674 (1652)
    Click OK to terminate…
    Click CANCEL to debug…
  • Edward Troxel
    June 15, 2005 at 4:50 pm
    Right-click the link, choose “Save Target As”, and save it in your Vegas 6.0Script MenuExcalibur4 folder. The next time you use Excalibur it will use the new file. Remember, it ONLY works in Vegas 6.0b
    Edward Troxel
    JETDV Scripts
