Excalibur 3 Or 5 Questions – Two Cams All Set In Long Project
sorry about caps lock…
i have 2 cams all synced up ready to go
what i do not understand about the multi cam wiz is… adding the video tracks…
does it see my existing timeline???
i can see where sync media shows both ppip… but can;t see eny “where i am now ” video unless i were to literally cut out 1 track by hand – but even then i don;t see the “active video”
OK… do i add every clip from my timeline physically, or what… i did select all of the clips that were in my timeline (one after the other in 2 cams in time line… put these in the “add” section of excalibur – and i ended up with a new project with about 2 dozen clips stacked on on top of the other in tracks…
obviously i’ve never used it before…
or.. do i have to add each clip 1 at a time and switch until that’s done then add another set of clips and continue… I sure hope not!!!
the demo shows adding 3 single clips… but who’s video is just one clip on each track? – which leaves me to wonder…
so…what am i missing?
Wayne
