Activity › Forums › Adobe After Effects › Exact location of anchor point?
  • Exact location of anchor point?
    Posted by Jason Brown on July 10, 2006 at 1:56 pm
    Hey Everyone,
    I need to prove a co-worker wrong!
    Is there a way to locate an anchor point at the *exact* middle of the bottom pixel of an image (or an exact corner)…without having to look at the info palette and do the math?
    I ask this because it seems that I saw a video tutorial where an asset was imported and the anchor point was located at the exact bottom left corner, because he did a rotation right off the bat.
    Thank you in advance,
    -Jason Brown
  • Steve Roberts
    July 10, 2006 at 2:16 pm
    Select the layer and hit the A key. This will reveal the anchor point position.
    For example, for a 640×480 layer, the corners are:
    (0,0)
    (640,0)
    (0,480)
    (640,480)
  • Filip Vandueren
    July 10, 2006 at 2:30 pm
    If you open up the footage in a layer-viewer (double click it in the timeline),
    you can drag around the anchorPoint with the move tool (if it’s visible).
    Now holding down the Command+Shift keys (Ctrl+shift on PC i guess) while doing this,
    the anchorPoint will snap to the center of the footage, to a corner or anywhere along the edge.
    This behaviour is not available in the Comp viewer using the Pan-behind tool.
  • Sam Moulton
    July 10, 2006 at 3:15 pm
    you can also let ae do the math by typing *2 after the value for either the x or y to snap to the rifht or bottm edge or 0 for the top or left
  • Accountclosedduetonorealnameused
    July 10, 2006 at 6:22 pm
    OR, if you’re really clever, you can run this little script that can move it to any of the 4 corners, the center edge of either of the 4 sides, or the center. Exactly, so there are no errors, especially when joining layers in 3D space etc.
    https://www.nabscripts.com/Downloads/(vrac)/repositionAnchorPoint.jsx
