Activity Forums Apple Final Cut Pro Legacy EX3 to FCP workflow
  • EX3 to FCP workflow
    Posted by Ceri Allen on May 20, 2010 at 3:28 pm
    Hi
    When working with footage form the EX1 or EX3 I am accustomed to using Sony XDCam transfer to import footage into my machine and then simply dropping the converted media files into FCP. Its a painless and reliable process form what I’ve found.
    However I have heard there is a process that avoids this and you can import footage from the card direct into FCP using log/transfer. Can someone explain to me exactly how to do this and if I need to install any plugins for FCP?
    thank you
    Ceri
    Rob Grauert replied 16 years, 4 months ago 2 Members · 1 Reply
  • Rob Grauert
    May 20, 2010 at 3:47 pm
    We have these cameras at my work and I just ingested from an SxS card yesterday for the first time. It was real easy.
    FIrst you want to back up the original file structure of the SxS card to a hard drive / LTO / blu-ray / whatever/
    Then you want the Log and Transfer software from Sony:
    https://pro.sony.com/bbsc/ssr/micro-xdcamexsite/resource.downloads.bbsccms-assets-micro-xdcamex-downloads-LogTransferUtilityAppleFCP.shtml
    Then all you have to do is open FCP and go to File > Log and Transfer. Yesterday, the media mounted automatically. If it doesn’t for you, there is a button in the top right corner of the window that looks like a folder with a plus sign on it. Click on it and locate your media.
    Also, I am working with FCS2. I’m not sure if it’s different with FCS/FCP7. I doubt it is though.
    Rob Grauert, Jr.
    http://www.robgrauert.com
    command-r.tumblr.com
