Activity Forums Apple Final Cut Pro Legacy ex3 reconnect problems
  • ex3 reconnect problems
    Posted by Timothy Reed on March 17, 2010 at 1:09 pm
    Process:
    file transferred BPAV from cards to HD
    Imported to FCP.
    Edited seamlessly
    Moved BPAV files to another HD to free up space
    could not reconnect files but I could re-import them manually
    what am I doing wrong?
    Tim Reed
    Timothy Reed replied 16 years, 5 months ago 1 Member · 1 Reply
  • Timothy Reed
    March 19, 2010 at 5:18 pm
    You can only reconnect to the import (mov) files associated with the sonyEDcam import function on the FCP.These files can be transferred among the hard drives and reconnected. If the BPAV files are reimported and they are then independent of the original mov files. the reconnect function does not distinguish between BPAV files and MOV files in the search mode.
    Thanks for everyone’s help on this won.
    Tim Reed
